I have a 30 amp breaker with a 10/2 feeding a 220 volt dryer outlet. Currently it is powering an air compresser in the garage. I want to put in a 220 wall switch so I don't have to go to the panel and turn on the breaker to power the compresser.
Can I use 12/2 from the 10/2 to switch and back to the compressor outlet?
  • First and foremost! 10/2 is not, and never was, legal to use for a 120/240V electric dryer circuit. An electric dryer requires a neutral along with the 240V feed. 10/2 would be just two hots and a ground if used for 240V. ........Secondly, doesn't the compressor have a switch right on it? Nov 29 '15 at 16:12
No. 12 AWG wire is only rated for 20 amperes, and so cannot be protected by a 30 ampere breaker.
The switch also has to be rated 30 amperes. Which should solve your problem, as the 30 amp switch should accept the larger wire.
    In addition, you need to make sure the switch is rated for 30 amps.
    – DoxyLover
    Nov 29 '15 at 1:05
NO. Use #10 wire and a 30 amp 2-pole switch.
Like the other's said, no.
This is because the switch will carry the load so it and the wire have to be sized accordingly.
