Can I use #8 copper with a 50amp breaker to wire my sub panel using 3/4" electrical PVC pipe running two leads one neural one ground. I have a 125amp sub panel this is for a new addition with full cellar one bed room one bath
    I'm not completely sure what you're describing by "...running two leads one neural (sic) one ground." Presuming you're covered by the U.S. electrical code (or a virtually identical one like Canada), you need 4 conductors for your subpanel. That's two (2) hot leads, one (1) grounded ("neutral") lead and one grounding conductor. – Craig Nov 27 '15 at 20:06
Sounds about right, as long as the new panel isn't too far from the original panel. You'll need 4 conductors, two ungrounded (hot), one grounded (neutral), and one grounding.
