I want to install a recessed outlet behind my TV but I am not sure how to get electricity to the outlet. There is an outlet at the bottom of the wall, below the TV.
Can I run a Romex 14/2 wire from that outlet up the wall to the newly installed outlet behind the TV?
I ordered a Arlington Industries Inc. TVBR255KGC-1 but after taking it out of the box I realized how big it is and does not fit in the middle opening of my wall mount hardware. I could put it below, or above the hardware, if I have to. But it's big and ugly.
EDIT: My breaker box is in a tight spot but I was able to get my camera in there and take some pictures. It's a 15 amp break that controls the outlet at the bottom of the wall.
Picture of the breaker where you can see (barely) that's a 15 amp breaker (third one down from the top):
Picture of left side of receptacle:
Picture of right side of receptacle:
The wires attached to the receptacle are not color coated, but the screws are. Which is white, and which is black?
Can I attach my 14/2 wire to those screws and run it up the wall to the outlet I install behind the TV?
