Started happening about 3 weeks ago. I have run the HOT water, put it in a glass and waited a couple of minutes: NO SMELL. I ran the cold water and put it in a glass and waited...NO SMELL
I have a septic and well water Husband has cleaned the pipe under kitchen sink..there was nothing there
Can you help ? Jan
    So if the hot water and the cold water have NO SMELL, what does smell? The only other option is the drain right? What does it smell like?
    – JPhi1618
    Nov 23, 2015 at 16:47
  • Sulfur/eggs. I've used Baking Powder and Clorox in the drain. Still smells. WHen you turn the water on you can smell it. I put the 2 gls away from each other and away from the sink. they do not smell
    – Jan
    Nov 23, 2015 at 16:49
Sounds like the anode rod in your water heater needs to be replaced.
Possibly with an aluminum/zinc alloy rod instead of magnesium or aluminum. This is the chepest fix.
Many claim the an all plastic water heater (e.g Rheem's Marathon) cures this problem since it doesn't have the anode rod that metal water heaters have.
I thought one of my sinks had smelly water, but it was from the drain and only happened when the water was running.
  • When it doesn't smell, run water into a pan or something so it doesn't go down the drain. Does it smell?
  • Set the pan aside and run water from the faucet normally. Does it smell?
If only #2 smells, then it's the drain. If it's improperly vented, then the smell may not have anything to do with the trap under the sink. Pouring stuff down the drain won't fix gas venting.
