I just moved into a new house I went to turn on the gas for the fireplace using the key yet I still can't light the fireplace. There's nothing showing me where to turn on the gas flow to the hearthmaster gas fire place. We have a natural gas oven which is working fine. Any ideas?
  • Tried checking the web go see if an instruction manuall is available for download? – keshlam Nov 22 '15 at 23:32
  • Might it be controlled by a wall thermostat? – Jimmy Fix-it Nov 23 '15 at 1:13
  • Did you ever get this resolved? If so, please give a check-mark to the answer or write up your own answer explaining what you did to get it fixed and give yourself a check mark. That will help others with this kind of problem know that this has a resolution and is a good place to look for their answer. – FreeMan Aug 3 at 11:57
There should be a thermocouple and gas valve - the thermocouple senses when the fire goes out and turns the gas off. Probably a pilot lite also. Check for a diagram online, here is a link to a youtube example:
https://www.youtube.com/watch?v=61DP2Spo4qk
second link: https://www.youtube.com/watch?v=CvL_fAFRIW8
| improve this answer | |
