Our garage door, pictured below, is right on a sidewalk that slopes downward slightly as it moves past the garage. The result is that one side of the garage door is 4 inches below grade while the other side is 1 inch above grade. There is no drain. A previous owner attempted to keep water out by pouring the cement bump right at the door you see in the picture below to force water to run past the garage door. The problem is that the bump is cracked and does not form a seal with the garage do, so a little water (not to mention draft) still gets into the garage when it rains.
I'm considering repouring the bump, ensuring it is more flush with the garage door, and adding weather stripping. What do you guys recommend? Alternatives? Is it worth considering some type of drain?
