I'm working out the details of my Mini split.
I know by code I have to have it connected to a 3/4" condensate line going outside. The Mini Split's air handler is located on an inside room where I'm forced to use a condensate pump. I currently have the condensate pump pushing out water directly via a clear hose 3/8ic hose and it's fine for now, but I want it to code.
My initial idea is to have a PVC with an elbow inside the attic to outside, and put a 3/8" bib on the end closest to the air handler and let it pump away and make sure there is a downward incline in the hose to make sure the water runs out of the house. Is this the best way? do I need a tee fitting like my whole home AC unit ( straight pipe with some sort of T fitting with no pipe on the top, and it continues out the house )?
I'm looking at doing something similar to this: https://youtu.be/HJwFgi3D-6g?t=58 at the 58 second mark
Just trying to get an idea of what I need to do. Seems straight forward, but I know that nothing is ever what it seems when you don't know what you don't know.
