So, I started with What type of screws and anchors are used for concrete? - but it's not particularly clear to me.
I (hammer) drilled 5/32" holes into an exterior wall for 3/16" tapcon screws. These didn't hold. So now I'm wondering what kind of anchor I should be using -
- Wedge?
- Sleeve?
- Split?
Or can I use a standard plastic anchor I have, assuming it fits properly? I can't seem to wrap my head around the differences in these "concrete" anchors except that wedge shouldn't be used for block, only solid concrete.
The wall is stucco of minimum depth, then I'm guessing cinder block. It's not brick.
I need to drill in and still have maybe 1/4" sticking out to hang a garden hose mount. So in terms of strength, I just need to hold say a 25 ft garden hose that may or may not be completely full of water.
