I have a table saw that can accommodate a 3/8" dado stack.
I need to cut 3/4" wide x 3/8" deep dados in a 3/4" thick delrin sheet. The table saw is the only tool I have that can really do something like that.
What kind of blades do I need and can I stack them?
It's a 10" blade at 5000 rpm, is that speed appropriate for cutting delrin? How fast should I feed it? I'm prepared to trim sloppy edges I just don't want the saw to bind.
  • Just cut it the way you would cut wood. Nov 15, 2015 at 1:44
Most (not all) dado sets run a bit smaller (you might use an 8" on a 10" saw)
You'll want to feed pretty fast to avoid melting.
This page suggests a sawing tooth speed of 1600-2600 feet per minute for Delrin (acetal homopolymer). That would require about a 2" diameter sawblade at 5000 RPM if my math is up to snuff. A 10" blade at 5000 RPM is 13,089 feet per minute. A 6" dado set (if you can find one to fit) is 7,853 FPM. 2" (which I've never seen in tablesaw blades, and most saws would not get above the table, I think) is 2,617 FPM.
You may want to find another method/tool.
