I recently did some patch work on my bathtub caulking. Just a little to give it a few more months before I redo the entire bathtub. My tub is floating and has a tub surround.
My wife usually removes the caulk during the day and she prefers that I do the actual caulking as I am better at getting a good bead size.
One of the steps she does to prepare the scene for me is full the bathtub all the way with water for what she says "so the caulk wont pull away". My personal problem comes from the tub water was not full and I did the patch work. My wife was against that and insisted that I fill the tub and start over. To make all parties happy I did just that.
What am I accomplishing by filling the tub with water? The weight from that does not reflect the weight that will be in the tub (estimation alert) 95% of the time. If filling the tub with water is beneficial why all the way?
Most of the instructions I ran into make no mention of filling the tub with water at all.
    I don't see the point. Either a) You caulk with an empty bath, and the bath deflects a bit when you put water in occasionally, or b) you caulk with a full bath, and the bath deflects a bit when you take the water out. – AndyT Nov 12 '15 at 14:20
    Why on earth does your wife usually remove the caulk during the day? Once it's applied why can't it be left there? – Myles Nov 12 '15 at 20:34
  • @Myles As a favour to me. I hate being there with an exacto knife scraping the residual off. She values showers and does whatever she can to accelerate the process – Matt Nov 12 '15 at 20:42
    @Myles I believe what he means is that when he is doing work like this his wife will remove the caulk during the day so he can do the work in the evening. I don't think he means that his wife randomly removes the caulk and he ends up having to re-do the work. – Sherwin Flight Nov 13 '15 at 5:30
  • Are we in an episode of the twilight Zone hear ? – Alaska Man Aug 18 '18 at 6:13
45
While caulk is fairly elastic, it handles better under compression than tension. By filling the tub all the way, you expand the gap quite a bit. Once the caulk is applied and the tub drained, the caulk compresses. During normal use, the caulk will likely never be in tension. As you'd have to add more weight than a tub full of water, before the caulk had to fill a gap larger than when it was applied.
Also, there's an old saying. "Happy wife, happy life" - Unknown
    It's not so much the caulk itself but the interface between the caulk and the bath/wall. Compression tends close up cracks, tension tends to open them. – Peter Green Nov 12 '15 at 21:47
Depends on the tub, to some extent, and how (or if) it was bedded when installed. Acrylic, fiberglass and thin steel tubs do noticeably deform with a load, especially if not bedded (I'm a fan of the good old plaster bed under the tub.)
Most cast-iron tubs don't deform to any noticeable extent.
  • Are you saying that I should fill it all the way every time I re caulk then? I would think that I should not fill it that much as that is not the weight the tub will experience all the time. – Matt Nov 12 '15 at 14:16
  • One day I will redo the tub as the surround is about 3 inches ahead of the tubs edge. That is a problem for future Matt though. – Matt Nov 12 '15 at 14:17
  • 5
    I think you should partially fill it with your wife in it. That way it will suit her precisely. – chasly from UK Nov 12 '15 at 15:03
the water pulls the tub to the position it is in when you take a bath the sides slitly deflect and it pulls down from the surround so filling is the best practice to fill the voids and have a longer lasting seal that wont leak
    I dont think it will be as bad on a re calk, but a first time I always fill er up – Ed Beal Nov 12 '15 at 14:26
