We are trying to put in an interior window between a room and an addition to the home that was added later. We cut out a hole in the drywall between the studs of the original room. However the studs of the addition are flush with the existing wall and are overlapping where the window will go by about 3 inches on each side. I was wondering what the best way to go about moving the studs would be. Would I need to put in a header?
Thanks for any help.
