I want to install hardwired, under-cabinet lighting, but I need some guidance on what kind of devices (transformers/drivers/adapters) I need to complete the project. I know very little about electricity and even reading some of the electrical answers on this site (like this one) have my head spinning so I'm hoping somebody can just tell me what I need. Here is my situation:
The rectangles (A-F) are my wall kitchen cabinets. The yellow wires (1-5) are the wires already setup (connected to a wall switch), on a single circuit, carrying 120VAC. 1 connects to 2, which is connected to 3 and so on.
I want to use something like this.
However, my difficulty is most of these LED under cabinet light solutions on Amazon seem to be assuming that you have one set of cabinets, where you can link all of your lights in a perfect row, and one plug that you will then plug everything into. I don't have that. I have 5 120VAC lines, and one of those lines (#5) needs to have 2 lights interconnected (for cabinets E and F) on that one line (why it was setup like this is another story).
So if I were to buy the light kit above (or something similar), please tell me what [else] I need such that;
- I can plug a single LED strip (or puck) into the 120VAC lines on cabinets A, B, C and D
- I can plug two LED strips (or pucks) into the 120VAC line on cabinet E
In case it matters, the scenario illustrated here is slightly more simplified then my actual setup. In my actual setup, there are two more cabinets. One touching cabinet 'F' (call it cabinet 'G'), and another cabinet which is stand-alone just like cabinet A (call it cabinet 'H'). So there are really 8 cabinets, and 6 lines coming out of the wall, but I didn't include them in the picture to try to simplify the scenario. I add them here incase it matters (for voltage/wattage/amperage/gigawatt consideration).
Also note, I'll probably have somebody else do the installation, but I still want to know what I need so I have it ready for whomever does the install.
EDIT: It has come to my attention that I can run 12V DC current on Romex. So is there anything wrong with setting up a transformer at line #1, to convert the current to 12V DC continuing down the line to points #2-5? That way all I need is one transformer at cabinet A. Assuming the transformer can handle the load of all the LEDs total wattage, is there anything wrong with this approach?
