I am looking for a way to remove the protective sheath from a length of multicore mains electrical cable. It's rated for outdoor use and is VERY strong. Without butchering my fingers; trying to fine cut it with a utility knife and without cutting into the hot wire insulation (and exposing the bare copper) in the process. I've already made 4 such errors and inflicted 2 knife cuts.
stabbystab
  • So; what exactly is it that you're doing, or wanting to do? Take care. – voices Nov 11 '15 at 19:41
I've usually had good luck with a decent quality wire stripper with NM sheathing cutters. After you clamp down on the cable you just have to pull a lot harder than on NM to break the last bits of sheathing that go around the ground. I have something similar to this:
Image from Home Depot, does not constitute a recommendation for the vendor, the manufacturer, or the model pictured.
Stripping UF is a bear. The usual NM strippers won't work for me, you'll nick the wires. Luckily, there is a stripper made for the task:
Ideal Industries UF Stripper 45-235
Unfortunately, it isn't cheap. Costs less than losing a finger though.
I'm a little unsure as to why you're doing a lot of stripping on wire you apparently want to keep using, but no matter.
I use an olfa brand knife (box cutter with a blade you can extend a variable distance) with the blade out 1/16".
Olfa knife
You can grip the nose of the knife between thumb and forefinger and use your fingers to ride the crown of the wire. Try to set the wire on something solid so your other hand isn't in the way. Once you've scored the sheathing, you can usually pull it apart either by hand or with pliers.
-2
AUTOMATIC WIRE STRIPPER/CUTTER/CRIMPER
PART NO. K4001
KINCROME K4001 - Stock Photo
FEATURES:
• Ratcheting Handle With Built-In Guillotine-Style Wire-Cutter.
• Strong, Firm, Adjustable, Multi-Point Vice-Grip Jaws.
• Linear Wire Stripping Motion. (Won't snap Cables).
• Strips 24-10 Awg (0.2-6.0 mm^2) Insulated Wire.
• Crimp 22-10 Awg (0.5-6.0 mm^2) Insulated Terminals.
• Crimp 22-10 Awg (0.5-6.0 mm^2) Non-Insulated Terminals.
• Crimp 07-08 mm Ignition Terminals.
KINCROME K4001 - Cuts & Crimp KINCROME K4001 - Grip & Strip KINCROME K4001 - Strip & Quit
  • Haven't finished this post yet. Will be adding more. – voices Nov 11 '15 at 19:43
  • Looks a whole lot like an ad to me, although your rep on other SE sites suggests otherwise. You might consider taking the promotional language out. – Daniel Griscom Dec 6 '15 at 0:10
  • @DanielGriscom An ad? Promotional language? I don't really see how that's fair. I'm not on the company's payroll if that's what you mean. Someone asked for a product recommendation. This is a product that I personally own, use and recommend. I'll say it again; I recommend this exact product, model, manufacturer, brand, and whatever else. Why? Well.. Because it's good. Also, I provided some specs.. FYI: I own a lot of tools. I had a few others to recommend as well, I just haven't gotten around to adding them yet. – voices Dec 6 '15 at 2:17
  • As reviewers, we're on the lookout for spam (i.e. unsolicited advertisements where the poster is part of the company and doesn't reveal his linkage). Your post looks a lot like spam, although again I doubt it is because you aren't new to the site and have done good work elsewhere. I didn't downvote it; why do you think other people did? – Daniel Griscom Dec 6 '15 at 2:29
  • So, "fair" isn't part of it; I'm just stating the facts, and others have reacted the same way (again: note the downvotes). If you added a "This tool has worked well for me because..." paragraph at the top, I bet people would react better to it. – Daniel Griscom Dec 6 '15 at 2:31
