I'm getting channel 5 to come in on my living room TV through a rooftop antenna. This station is not coming in my bedroom. I'm using a splitter in the basement.
I've tried different antennas, cables, and even an amplified splitter but still can't get channel 5 in the bedroom. I also tried plugging in a small TV antenna directly into the bedroom TV, but still no-go. If I plug the bedroom TV into the same jack where the living room TV is plugged in, I do get reception of this station.
Any ideas on how to get this to come in or why it's doing this?
UPDATE: I finally got this resolved by using a 2-way splitter for the tv that was having issues and directly connecting one of the “out” ports to the TV in question and the “in” to the rooftop antenna. Then I connected a coax cable connected to the “in” port of another splitter that has “out” ports that connect to the other TVs in our house. I also adjusted the antenna to get the best signal.
