This is related to this question:
Can I accelerate caulk drying by using a fan or heater on it?
...but that question kind of veered off into talking mostly about silicone caulks.
I'm trying to caulk parts of a deck I just built (namely around the railing posts). It's wet and cold (pacific northwest) and the silicone caulk I initially used never set after 3 days. So I thought I'd tray an acrylic based one (DAP Dynaflex 230). Can I speed up the cure time on this with some technique? Perhaps heat? I can't find any definitive answer as to whether heat helps acrylic caulk cure faster. I can only find references that heat does not help silicone caulk and actually is a way to remove silicone caulk.
