I'm building a remote button to flush a toilet and I need a temporary power switch - something that will run 120V for say 3 to 10 seconds....
I have googled extensively and have not found anything...anyone have a solution?
correction, power is 12v - motor I'm using is DC and I have a transformer.
Also, I found what I need: "timed delay relay".
The timed delay relay will power a motor that lifts the flush handle and then shuts off. Like a piston crank shaft.
I will update with a DIY when/if I finish this.
