So I came home today to find my living room at over 80f degrees. My thermostat still correctly showed my base temp at 70f, but the room temp was through the roof and the ceiling heat was still going strong. I tried pulling the thermostat from the wall and disconnected the two wires so they dangle free, I left my place and came back a few hours later to find it feeling like I just opened a door to the Amazon jungle. I ended up shutting off all of the breakers since I didn't know which one the system was connected to and finally the room began to slowly cool down.
Now I'm stuck with no power and a ceiling that keeps heating, so there's some problem with the system itself. Unfortunately I found out the only company in the area that deals with these ceilings charges a ton because they know they can, and I'm just about fed up this and want to see if I can handle this myself before calling an overpriced professional. My questions are:
- Does anyone have any insight as to what the issue could be? I'm assuming it can't be too complex and should be simple to identify.
- How can I identify where the system is connected? If it's some drywall I have to cut open, is there an indication where that might be?
- Is it something that I can realistically do myself? I can go without electricity in that section for as long as it takes, and I have some experience wiring home electrical systems and general home renovation work.
I appreciate any help, which will in turn help anyone else in the building if I find out the work can be done without a pro.
