I keep hearing how adding Floetrol gives much better results when painting mouldings and doors etc. As gloss paint is almost always used for these surfaces, my question is: why does gloss not just have this substance added as standard by the paint manufacturer?
Any thoughts?
  • I'd like to know too, and there must be a reason... Some thoughts (could all be wrong): Reduces coverage/hide, reduces shelf life, affects drying time, increases cost or affects adhesion? – JPhi1618 Nov 9 '15 at 15:11
  • I imagine it's because different paint viscosities make sense for different situations, such as material being painted, desired thickness of coat, temperature, humidity, etc. If you need a range, it's a lot easier to start with something on the thick side and thin it out than vise versa. – YWCA Hello Mar 8 '16 at 3:06
  • I have the same question. I purchased SW Emerald at $70 a gallon and it dries (within 1-2 minute) so fast that I consider adding Floetrol. Why SW is not at least presenting Floetrol has an option? – Martin Aug 2 '17 at 14:36
