I have a 3" drain running horizontal. I will have a new 2" drain running horizontal to just above the 3" drain at an angle and need to connect them together.
I assume I shouldn't use a regular T here, but should i be using a wye, sanitary tee, long sweep, something else? I'm a little confused on what connector is proper. If I have any options, something that leaves the up spout part as low as possible would be best, as I'm going to be pushing the drain slope requirements as it is.
