I have to build a door frame on a staircase.
Problem is, at the bottom of the staircase are already 3 doors on all the walls, so putting another door right at the bottom of the stairs (on the landing) would make the new door totally overlap one of the existing doors at the bottom.
So, I'm thinking to build the frame 3 steps up the stairs, so the door can swing open and not overlap the other doors. But then it wouldn't open on a landing, it would open on 3 steps of stairs THEN a landing.
Somebody mentionned that there's a safety hazard because the door wouldn't open on a landing, but then again if you're coming down the stairs, you've been up the stairs before so you know there's no immediate landing??
Is the code against this, or is it up to me to decide?
EDIT: About putting the door at the top of staircase, the top floor is big, open "loft" type of room and the staircase leading up to it has no ceiling. It would be hugely impractical to frame a door at the top because..there is no wall or ceilings around the top of the staircase, just a guard rail :)
The main reason for putting the door at the bottom was to block public access to the stairs (the bottom floor of the building is a restaurant, the top floor residential -- very old building)
