I'm not sure what these screws are called so I'm not sure what to search for.
On mobile having trouble tagging, so feel free to edit.
Below are pictures of the screw in its deployed and non deployed state
Basically it's a wide head screw that screws into the wall in a non stud area, and a normal screw is screwed into that. The screw in question (that goes into the wall) has a "flap" or piece/hinge that deployed in the wall to balance the weight I'm assuming.
I can't figure out how to get them out of the wall when the hinge is deployed. Any ideas? I'll try to upload a picture of I can
The anchor shown is one of the variants of toggle bolt/anchors that have sections that slide laterally after they are inserted into the wall. It is virtually impossible to remove these without doing some damage to the wall. As @ojait has suggested in his answer describing hollow wall anchors (sometimes called mollies), you really need to push the anchor in since you can't pull it out.
The easiest way is usually to use an awl and drive a series of small holes around the perimeter of the anchor flange. Then use a screwdriver (phillips would probably work best) to push the anchor into the wall cavity. Patch and move on.
The original toggle bolts were a breeze to remove. When you removed the bolt, the separate spring loaded toggle simple fell into the cavity, leaving a neat hole to patch. Newer toggles use a flange on the outside and retain the sliding toggle so that the bolt can be inserted and removed repeatedly. The ease of reuse is offset by the difficulty in eliminating. (I still think they are a vast improvement over the original.)
I believe you are describing an "expansion wall anchor". Here is what the manufacturer states:
Primarily used in drywall, the hollow wall anchor is a medium duty fastener. Once the body of the anchor is installed, the screw can be removed and items can be changed without disrupting the anchor. The tip has a drive point to pierce drywall easily.
Here is a picture.
The only way to remove any expanding or toggle-type anchor (with minimal damage) from the wall is to push the anchor into the wall hollow and spackle the opening.
  • If it's that anchor, I've had good luck with bending the flange back and forth to break it off, then pushing the remainder into the wall, as noted. (Sometimes I'll use needlenose pliers; other times, a 3" screw jammed in.) This will give you slightly less drywall damage to deal with. Commented Oct 31, 2015 at 14:34
    My solution for these has been to drill off the faceplate, then spackle and paint.
    – keshlam
    Commented Oct 31, 2015 at 15:26
  • In my area we commonly call that a "molly" anchor. Not sure why, probably a manufacturer's name that became the normal term (like romex). Commented Oct 31, 2015 at 15:48
