I have wood paneling on the refrigerator (it was there when I moved in). I'd like a stainless steel frig. There is nothing wrong with the current frig.
Is it worth replacing the wood paneling with stainless steel paneling? Is that even possible?
  • The make and model of the fridge would help. – Jack Oct 31 '15 at 7:16
  • I edited your question to change "steal" to "steel" so that it does not look as if you were thinking of trying to get something for free in an illicit way. – Michael Karas Oct 31 '15 at 18:18
Typically wood panels are installed as part of the cabinetry, the fridge panel is installed at the same time as the kitchen cabinets.
There is a removable edge at the door that is used to install and remove the panel. Once that is removed the panel slides out from one side. The replacement SS panel will go in the same groove that held the wood panel. The edge of the wood panel that went into the groove is usually 1/4" thick, so to add a metal panel in its place a backer of corrugated cardboard needs to be added in the back of the SS panel to keep it from moving excessively.
| improve this answer | |
  • Will the SS panels look cheesy or cheap compared to a real SS frig? – 4thSpace Nov 1 '15 at 0:27
