I am about to replace a load bearing wall in unfinished basement. There is flexible duct attached to plenum that I need to temporarily move out in order to put the beams in. Do i just need to cut the tie and pull it off the collar and then re-install and re-tie it back once I get the beams in place?
    Sounds about right, you may want to get some high quality duct tape to wrap the joints with. – Jimmy Fix-it Oct 30 '15 at 19:52
