I have a lot of frozen countersunk T10H security pin Torx head 6-32 screws to remove from cast aluminum weatherproof enclosures. I have tried tapping, torqueing in both directions, penetrating oil, heat gun and ice/freeze mist. Tried to use a drill press and clamping the enclosure in a vise, but even then, the security pin makes the drill bit "walk" off the very hard screw. Someone told me there is some kind of electrical device used my machine shops to remove screws from engine blocks, etc., by "burning" the screw out. Will this work on screws as small as 6-32? If so, what is the device called, so I may intelligently call around to machine shops to see if they possess one of these devices? Any other ideas? I have snapped screws off and also snapped off about 5 T10H tool bits. I there any special penetrating oil for stainless steel to aluminum tapped holes?
Since it sounds like you're desperate, here's an idea: knock the security pin off by hitting it sharply sideways (usually a nail set will work), then use a normal (ie, stronger) T10 bit.– Aloysius DefenestrateOct 28, 2015 at 23:30
1Are you using T10H Torx bits to try to remove them?– bibOct 29, 2015 at 12:57
You are looking for Electrical Discharge Machining (EDM) and some versions should be able to work at the size you need.
The simplest solution is using a screw extraction kit. Since you know the size and threading, once you drill and exact the security screws, you simply replace them with the appropriate sized non security screws. Or you know, use new security screws if you need that extra bit of annoyance. It's not like security bits are hard to find, you broke 5.
As a preventative method, apply anti seize oil/grease/tape to the new screws.
I have used a small battery powered Dremel with a abrasive cut off disc to cut a screwdriver slot through the middle of head. Start off by making the smallest slot you can. You can always make it bigger and get a larger blade screwdriver. Just be careful how deep you go as you might break off part of head off while turning and screw will remain. Old reliable slotted screw heads.😉
Are you suggesting that a slotted screw driver will get a better purchase on a corroded in place screw than a Torx bit will? You must have very different slotted screwdrivers than I do. I don't use slotted on anything except light switch cover plates if I can avoid it!– FreeManFeb 25 at 13:01
