Is there code on this? I am having an egress window well installed today and was surprised to see the window well sticking out 2 feet above ground (1 foot if you count all the new dirt they mounded up around it). I was surprised because in all my research, most of the wells seem to be closer to flush with the ground (very few images I see on Google image search seem to have the well set so far above ground). It is far more of an eye sore than I was expecting for the $4,000 price tag associated with the work and the initial pictures I was shown before signing a contract.
The installers said it is required to have it set above ground so that people do not fall in and that most people cover the wells with shrubs, but I do not recall reading this in any applicable building code and it seems like planting shrubs to cover up a fire escape seems like a generally bad idea.
Can anyone confirm whether what I am being told is correct with an applicable code reference (if one exists)? If it is not required, I definitely want the well set an appropriate depth (or a shorter well placed) as I am unhappy with its appearance and would prefer to not have to do my own decorative brick work to cover it up.
