I have built the start of these stairs. It's a difficult concept for me to build stairs around a corner so I cut part of the deck so it wasn't an abrupt 90 degrees going into the stairs (which wouldn't have really worked anyways).
I am at the point now of putting the tread on the stairs. I have a few boards screwed down already to keep the spacing between the stringers the same but how do I go about getting rid of the gap between the first tread and the stringer "toes" edge?
You can see in my picture there is a gap where I placed my pencil. My plan was to cut the boards at the same angle the stringers are at. So basically every board will end on a full 2x4 stringer top. Thats why I doubled some stringers. Any thoughts? Even if I cut the board on the left at an angle I will still have that gap. You should be able to see the pencil in both pictures.
