Ive been told there are a diffrent results of asbestos ie low medium or high , ive been living with a huge hole on my sitting room ceiling for seven weeks with parts of it falling daily as a result ive been picking this up with my bare hands , ive now been told its only dangerous if you handle it , ive bee told its a low result and wont effect me or my children but i have been handling it as shards have fallen and ive picked it up
  • You can handle asbestos as long as you do not breath it. I'll write you up an answer with more detail. Also, ceilings often have very small amounts, so crumbling may not be releasing the strands in to the air. – Terry Oct 21 '15 at 16:15
  • Yeah, asbestos is dangerous when it is in dust form and inhaled. Asbestos isn't a poison; what happens over time is the tiny dust gets trapped and scars your lungs which increases your risk of respiratory disease. I'm not 100% sure, but personally, I would feel comfortable touching it with a bare hand if I took precautions against the dust. Precautions against the dust is a tricky subject though; there is basically no filter that can filter asbestos dust. I won't recommend what you should do, but you're probably not going to be killed by a tiny amount of asbestos. – Zach Mierzejewski Oct 21 '15 at 16:27
Some ceiling tiles contain asbestos; some don't. If you want to be sure then you can have it tested. If the tests come back negative, then you can stop worrying! If you don't want to do a test, then I would do something about it right away, just in case.
Asbestos can cause problems when inhaled, but not when touched. If you've had pieces falling off of the ceiling, you may have fibers floating in the air.
The particles are small and light enough that they never really settle as dust. HEPA-rated filters will remove asbestos from the air, but only if they are attached to a matching HEPA vacuum. If you put an after-market HEPA filter on your shop vac there are any number of ways for the asbestos to get around the filter.
Keep in mind that asbestos is a politically hot topic. Some people believe that a single fiber will lead to inevitable cancer. Others believe that you have to breath fibers for years and then maybe something bad will happen later in life. The truth must be somewhere in between: Asbestos is a naturally occuring mineral, and is always present (in low levels) in the environment.
Either way, asbestos is a controlled "hazardous substance". If you get a positive result on an asbestos test then what I'm about to suggest may not be allowed (especially step 3). You can Google "asbestos remediation" for a lot of information.
I assume you don't want to buy a new vac. Then there are three things that I'd do:
  1. Stop adding possible asbestos to the air. You need to repair (or stabilize) the damage in the ceiling. This can be difficult to do without releasing more asbestos :) One common way is to cover the asbestos-containing material with sprayed-on paint. But this isn't appropriate if there is already damage.
  2. Be wary while cleaning up the fallen material. You can mix a small amount of dish soap into water and spray it onto the material. This traps the fibers so they don't get released while you scoop up the material. Keep it wet when cleaning it up and then tie the garbage bag closed. If the material is known to contain asbestos then it is generally illegal to throw it into your residential garbage container.
  3. Ventilate the room. Get a lot of air flowing through the room through an outside window. Don't blow the air into the rest of your house. Any fibers will quickly disperse in the atmosphere. Again, this isn't generally allowed if the tests have come back positive.
