Last week an electrician started rewiring our whole house. They started by running new wires into all the rooms and running the wires into gangboxes and into a subpanel in the garage.
I assumed to finish the job they would install the outlets and switches, and then the last step would be disconnecting the power and installing the new main panel and then hooking the power into the panel.
Would that be a typical/logical way to do it?
Instead, the first thing they've done is cut the power, start on installing the main panel and setting up the subpanel. There are zero outlets or switches installed on the new wiring, not to mention none of the light fixtures have been switched over to the new wiring either.
This seems like the exact opposite order they should have done things. Is there some reason for doing it in this order?
There's a really good chance we're going to have no power tonight, or at least only have power in a few outlets unless they work overtime (they started at 8am and it's almost 3pm now)
