Sorry if this is a silly question, but I've searched an haven't been able to come up with anything helpful.
I'm planning on wiring my house for Ethernet, and I'm going up to the attic to do some cable drops. My attic has blown fibreglass insulation which rises well above the top of the joists. All the advice I've read says I should carefully rake the insulation away from where I plan to walk, and lay down some plywood planks to make sure I don't accidentally step through the ceiling, and to rake the insulation back when I'm done. That's all well and good, but, I expect I'm going to complete this project over a couple of weekends, which makes me wonder, if I leave the plywood in place and rake the insulation back on top of it, effectively giving me a layer of insulation above and below my walkway, will the effectiveness of the insulation decrease?
Thanks in advance for any help.
