I installed my first ceiling fan with remote today. I believe I did everything correctly as the fan turns and the light lights, both via the remote control. My question has to do with the need for electrical tape.
I replaced an existing ceiling fan without a remote. I disconnected the blue wire (lighting wire) from the group of existing wires. I then connected the black wire to the black wire and the white wire to the the white wire. I used the plastic caps originally used to twist the wires from the remote to the wires coming from the ceiling. There was no ground (copper) wire. The box and support was already sealed.
The only thing I didn't repeat in this process was to re-wrap black electrical tape around the plastic connector caps.
Here's the question; Is there going to be a problem down the road because I didn't wrap black electrical tape around the properly capped wires from the ceiling to the remote?
