I want to replace a single pole wall switch that contols a closet light with a single pole pilot light switch. The pilot light is supposed to light when the closet light is on. The current wall switch is outside the closet. I looked in the switch box and there are two wires (ablack and a white) and a bare copper ground that are connected to the existing switch. The black and white wires are connected to two screws on the right side of the single pole switch. The new Leviton pilot light switch has a brass screw (top right), a black screw (bottom right), a silver screw (top left), and a green ground screw (bottom left). I know where the ground wire is connected. Question: How do I connect the black and white romex wires to the new pilot light switch so that the pilot is 'ON" when the switch is "ON"? There must be something simple that I am overlooking, but I can't figure this out. Help!
1Does the light turn on at all on the switch? I have some installed, but the pilot light is only on when the light is off - that's just how they were made. Does the package say it should be lit when on or off?– JPhi1618Oct 15, 2015 at 19:03
Wait, do you have the type where the switch and the light are separate and it uses an "outlet" type wall plate, or is it the type where the actual switch lights up? Link, model number or picture?– JPhi1618Oct 15, 2015 at 19:13
It appears the switch you've purchased requires a neutral and you do not have a neutral wire available at your switch (only the hot and the switched hot). You'll need to either run a line to the switch that includes a neutral, which is now a standard practice, or you need to find a switch that will work without a dedicated neutral. Finding the latter may be difficult as the versions with a dedicated neutral are fairly standard.
I thought it was possible they might have a lighted switch that could act as a 3-way (hence the extra screw), but in that case I don't think the screw would be silver.– JPhi1618Oct 16, 2015 at 14:24
To wire this switch you will need a third wire (a return leg) from the light fixture. If you can run the third wire than the switch can be wired thusly: Black (hot) wire from the box attaches to the brass screw of the switch, White (neutral) wire from the box attaches to the silver colored screw on the switch, the third wire (which you will need to install) is the return leg and it attaches to the dark screw on the switch. This will have it so the pilot light is only lit when the other light is on.
Hmm... a hot, a neutral, and a "return leg". Where is the switched hot that actually controls the light? I think the OP wants to use a switch with a light that indicates when switched power is directed to the load (when the switch contacts are closed), not use a "return" hot wire from the load. If you think about it, neither option actually tells you the light is on, what if the bulb is bad? Oct 16, 2015 at 18:04
Switches that feature a light which illuminates when the switch is "on" require a neutral conductor. There are switches which illuminate when the switch is "off" that do not require a neutral, this is because they trickle a small amount of current through the lighted switch component, through the actual switched load to the load's neutral conductor; the amount of current is so small that the load is not sufficiently energized as to cause it to operate (note: if the load were very small, such as a light bulb the size of the illuminated switch component, the load would operate, i.e. light up, while the switch was "off").
