Part of my bathroom is directly above the boiler room. The boiler room is only accessible via an external door and is well ventilated with wall and door vents, so I consider it more like an outhouse than part of the house interior. When the boiler is turned on, the boiler room gets quite warm. But the rest of the time, it's not much warmer than the outdoor temperature. I suspect that this is contributing to the bathroom getting quite cold (in fact I can feel a cold draft coming from under the bath), so I would like to add some insulation in the bathroom floor/boiler room ceiling.
Here's a cross-section of the part of the house in question.
house cross-section
Points to note:
  1. Most of the bathroom floor is tiled. Lifting the tiles to gain access to the floor space is not an option.
  2. The floor under the bath (behind the side panel) is not tiled, and is only partly boarded, so pushing insulation between the joists under the tiles from there could be an option but still somewhat awkward.
  3. The boiler room has a plywood ceiling, nailed onto the joists. I would rather not take it down if I don't have to..
  4. Pipes from the boiler (not shown in the diagram) go up through holes in the ceiling, make a right angle turn and go off under the tiles. The holes the pipes go through are much bigger than they need to be, which is probably how the cold air is getting in. These gaps around the pipes will need to be filled.
It occurs to me that the easiest way to approach this is from the boiler room side.
Can I just attach some insulated plasterboard to the ceiling of the boiler room?
If so, do I need to add a vapour barrier, and where? I understand that when adding insulation to the inside of a room, the vapour barrier goes on the warm side of the insulation. Here, I am effectively adding insulation the exterior of a room, and I'm not sure whether a vapour barrier is needed.
Any other pitfalls I should be aware of?
This is in the UK, typical brick-build house construction, in case that makes any difference.
In my opinion, public enemy #1 are the potential drafts that are coming through your structure. Address point 4 and use expanding foam filler around those holes and pipes.
That being said, I think you need to tackle the problem head on and remove the plywood, ala point #3, and properly apply insulation to the uninsulated space. It will not only beef up your homes thermal barrier, but in addition will insulate your bath, keeping hot-water bathes - hot.
Not sure about the door and wall venting, I'd hope you have the boiler exhaust piping heading outdoors..
  • Thanks for your answer. The boiler exhaust goes through a proper flue. The vents are, presumably, to ensure there's enough oxygen coming into the room for complete combustion, that is to avoid producing carbon monoxide. This is quite a large, old boiler. In a few years I'll probably replace it with a modern one and move it inside the house, at which time I'll no longer need a dedicated boiler room and can repurpose that room for something else. But that's for the future - for the moment, I'm just looking to make things a bit warmer.
    – MarkH
    Oct 26, 2015 at 11:05
  • Of course, and so I will assume there is no fresh air inlet that carries fresh air into the boiler. Have you removed the plywood to see what is under the bath? If I have answered your question adequately, please check off this question. Good Luck!
    – Raffi
    Oct 28, 2015 at 15:36
  • The only remaining question is about the vapour barrier. If I remove the plywood and pack insulation between the joists from below, do I need a vapour barrier and if so, how do I get it in there? I had another look under the bath (from above, by removing the side panel) and there are more floor boards there than I remember. Putting in a vapour barrier under the bathroom floor from above won't be an option without a lot of work. Is it sufficient to use foil-backed insulation panels without a separate vapour barrier?
    – MarkH
    Oct 28, 2015 at 16:14
Another option, if allowed in your jurisdiction, is to provide combustion air with a fan-in-a-can rather than the open louvers. The supply fan is interlocked with the burner.
