I have a 400 Square Foot garage that has a lot of gouges in the concrete floor. I purchased some primer and Concrete Leveler in order to fix the gouges. I made a mistake and accidentally mixed 4 times the amount of water in the concrete and applied it anyway. It looks bad, but I was hoping that there would be a way to salvage the application with another bag of the concrete leveler (Properly mixed this time). Is this the correct way to go about doing this?
I tried applying the primer on top of the incorrectly applied concrete leveler, but it seems to be absorbing it.
You really should remove the stuff that was mixed overly wet - that tends to make cement products very weak. As a result, it should be easy to remove - might even come out with a stiff broom, if not, stiff wire brush might well do it.
Check the labelling on your paint - in most cases you should wait at least 30 days before painting (or attempting to paint) any fresh concrete product.
