Need to replace this arm as it is supposed to attach to a gas strut but the inside thread has been worn out, i just cant seem to find the name of it.
  • What's the stripped thread made of, aluminum? You may get lucky at a local welding or machine shop. Adding metal to a hole, then re-threading is a possible option, if you've access to the equipment. The piece itself looks custom as all get out, which translates to $$$. Oct 11 '15 at 13:21
  • It is a specialty item, but it's probably still just referred as a hinge (for a top-hinge cabinet, I assume). Are these custom cabinets? Since at least the early 1990's, most cabinet companies have a lifetime warranty on the hardware. Can you find a brand name? It's usually on a tag inside the sink base cabinet.
    – paulmz
    Oct 11 '15 at 13:33
  • We will at least need a picture of a complete device. Usually the name of the maker is on the main body of the device somewhere.
    – Jack
    Oct 11 '15 at 16:33
  • Agreed: what was it being used in? It may not have a name or be available outside that manufacture's parts lists.
    – keshlam
    Dec 17 '16 at 22:12
