There are several boards with gaps. Some of the boards are uneven. We want to pull the boards together to create one larger gap to put a shim into. When installed the boards were glued together. How can we pull the boards together in order to make this repair
You are going to break some stuff up should you try to take it apart or even try to tighten it. – Jack Oct 10 '15 at 0:27
Add a comment
