I'm in the process of moving 240V outlet. The outlet has three wires connected.
In the junction box I can see the ground coming out of the outlet.
See the image:
So where is the ground wire inside the outlet? I'd like to know how this is handled. Update: for some reason I didn't notice ground attached to the neutral. But it is there
Then I noticed a orange label and found the instruction:
So I wired the stove cord according to the code:
Measured all the connections with the voltmeter and all is now set up correctly. Thanks to everyone!
