I am replacing a rotted out light pole in my yard. The underground feeder that runs to the light pole is only long enough to run halfway up the new light pole. Is it acceptable to splice an extra length of cable to run to the top of the light pole? I don't know if this is acceptable since there will be a splice hidden inside the light pole.
Uh, what is your concern? That the light pole might burn down? Is it made of wood?– Tyler DurdenOct 6, 2015 at 0:22
Metal pole. I just want to be sure I'm not overlooking anything. Im just not certain if a hidden junction in the pole is an issue.– tribusOct 6, 2015 at 0:43
Not really. Ideally, the connection should be made in an accessible place but if it doesn't reach, it doesn't reach.– Tyler DurdenOct 6, 2015 at 0:46
Maybe somebody that knows more than me could comment on whether "Tyco Electronics, Model # CPGI-1116377-2, Home Depot SKU # 302061 Romex Splice Kit 2 Wire" is acceptable in an outdoor setting.– Aloysius DefenestrateOct 6, 2015 at 1:59
2@TylerDurden A neutral to ground short is deceptively dangerous. Under normal conditions, no one will notice. But if someone touches the pole when they are a better ground conductor (ie, standing in a pool of water), they will be shocked. Trust me, some nimrod used the ground conductor as the neutral in my house and I got a good shock when I touched the metal box. Found this about a year after buying the house and it was just waiting for me to touch the box while barefoot.– dicelessOct 7, 2015 at 16:01
No -- splices need to be accessible in case something gets messed up and the splice needs re-doing. There should be a space in the base of the lamppost to make the needed splice/connection, though -- look for an access panel as part of the base.
Code says that splices have to be accessible, although I can think of two exceptions: My well has a splice between the direct burial line running across my yard to the 3 strands of wire that go down the bore. This splice is just in the riser pipe that brings power from the burial trench to the well cap. There is another splice at the pump. Those are covered with plastic waterproof compression seals.
Normally I would expect the base to have a built in junction box for splicing. After all, you may have multiple lights on that circuit. If it's a home made light this may not be the case.
Another possibility is that it's low voltage lighting. Code is a lot more liberal for that, since the risk of electrocution is much lower.
If you choose to ignore code, and splice anyway, I would suggest using crimp connectors and heat shrink tubing.
Yes, you can just splice it, but if possible don't just twist it and tape it - that's probably asking for a short sometime in the future, it would be best to splice and solder it and tape it.
http://nicab.co.uk/wp-content/uploads/2014/03/Wire-splice-solderikng.jpg
I strongly suspect this would be a violation of the National Electrical Code (in the US). Splices are to be accessible, and not hidden.– macNov 5, 2015 at 22:41
