I want to add an outlet behind my TV, and another in a nearby coat closet for the cable box. I don't have an outlet in a stud cavity below the TV so I need to fish one from ~6 feet over.
I'd like to keep the outlet on the same circuit (for my sanity when shutting things off later). Is it acceptable to run electrical down from the existing outlet into the basement and then back up into the wall cavity behind the TV? Or should I cut an extra hole in the drywall below the TV and drill holes horizontally, and fish it up from there?
