I've got this wall, from which I've ripped off the drywall. The wall is 5' wide, 9' high. There's 4 flimsy metal studs and I'd like to install a few big sheets of plywood over those so I can put up 6 five foot long shelves. I would like to join 3 cut up pieces of 2x4 to the big beam on top to block out a little past the metal studs, and then attach some pieces of 2x4 to the floor. After that, attach a long sheet of plywood to those 2 blocked out pieces. My question is, would that be a strong enough way to hold down an 8' sheet of plywood, only securing it by 2 ends? Here's a picture of the situation: img
    ...and exactly why are you not fastening to the studs?
    Commented Oct 4, 2015 at 23:37
    Is there a reason you don't want stand-alone shelving, which wouldn't get any strength from the wall? Commented Oct 5, 2015 at 0:56
  • When you say "securing it by 2 ends" does that mean that you only want 2 points of contact? I've seen this done with 4 points of contact, 2 on each end. Please clarify.
    – N8sBug
    Commented Oct 5, 2015 at 1:09
So, you've got lots of options, some of which no "real" contractor would ever do, but are perfectly fine.
If you use long drywall screws you can screw your wood blocking to the metal studs, just like you would if the studs were wood. Sharp screws will penetrate the metal studs. This is not optimal because your skill at doing this non-standard solution could result in shelf failure later, though it's probably what I would do.
You could do as one of commenters suggested and put stand-alone shelving agains the wall and attach it with brackets to the new drywall or directly into the metal studs- perfectly fine - very DIYish. Use drywall anchors.
You could screw shelves directly into the metal studs - they are studs - they hold weight - no problem. This is also something I would probably do. Use drywall anchors.
You could use 1/2 or 3/4 plywood on the wall instead of drywall. Kind of odd, but it will provide excellent holding capacity to attach shelving. (I have a plywood wall in my mudroom - shelving bolted right on.
You could attach vertical wood 2x4x on top of the drywall floor to ceiling, attached to the studs (essentially a new set of exposed studs). Then attach your shelving to that.
Basically, your goal is to get something that isn't going to easily rip away from the wall...and a nearly infinite variety of screws, wood and brackets will satisfy this.
  • This is along the lines of what I was going to give as an answer, but I would add blocking from one set of metal studs to the other since the pipes literally cut the metal studs in half and therefore will not let the wood studs make a complete path either. That would give enough strength to any wall if you attached the shelf standards to the wood studs. Lay on them if you like, they will hold, at least to the wall. The plywood you refer to would give you complete flexibility in fastening. Depending on the shelf system the OP is doing, one row of blocks at the top, will hold a hanging shelf.
    – Jack
    Commented Oct 5, 2015 at 16:05
The shear strength of a few dozen appropriate screws through 1/2" or better plywood into the steel framing, plus the load distribution of its own rigidity, will give you more than enough strength to carry several hundred pounds on your shelving. Some caveats:
  1. Be sure that the top plate is securely anchored to the framing above.
  2. Be sure that your plywood spans onto the top plate and fastens to it, as well as to the studs and any wood blocking you have in place. Not doing that puts a large load on the joint at the top of the studs. That could end badly.
  3. Be sure that the plywood is fastened snugly against the framing. Gaps weaken the system by creating a torsional load rather than entirely shear loading.
Note that the fastening power of any screw is largely dependent on its diameter--a 50% increase in diameter yields substantially more thread circumference.
