I just purchased a 2 year old home in the laundry room on the wall for the washer & Dryer there is 1 - 120v Jack and 1 Nema 14-30R Jack.
My washer only needs 5a 120v Nema 5-15R.
Do I need to run a separate breaker and a stand alone outlet? (GFI or arc Fault?)
Thank you "
    Is there anything that prevents you from converting the single 120v outlet to a dual outlet? I'm assuming the 120v outlet is already on a dedicated circuit.
    – diceless
    Oct 1, 2015 at 17:40
  • What does "1 - 120v Jack" mean?
    – Tester101
    Oct 1, 2015 at 18:01
If the 120V receptacle is a simplex (single) receptacle just replace it with a duplex. You can share it with the washer. This assumes the cord from the dryer will reach.
If you are unsure of how to do this please comment back.
