I would like to be able to convert our outside table into a table-tennis table for me and my children. The existing table is the right height (1" lower than standard table tennis table) and about the right size , just a bit shorter and thinner than the 9ft by 5ft size of a table tennis table, It is also slatted so not usable as a table tennis table on its own without a custom top.
So I simply want to create a top, I plan to create it as two separate parts split at the net of 4.5ft by 5ft so its fairly easy to remove. But what material should I use, and do I need to paint it to get a reasonable bounce. It doesn't need to be perfect but good enough so that it seems like playing proper table tennis.
Its going to be outside, and although I can remove it Id rather be able to leave it on so some resilience to elements would be useful.
Im based in the UK
  • almost any top can work. just be sure it is reasonbly smooth and not warped. paint it with a water-proof paint unless you get a water-proof material. – Skaperen Sep 30 '15 at 12:10
    In the 60s, plywood was pretty popular, and I've seen a fair number of those at summer camps. Put a lot of exterior grade paint on it. – gbronner Sep 30 '15 at 13:36
  • How about (green) mdf ? – Paul Taylor Oct 1 '15 at 8:57
