I'm trying to add recessed lighting into my hall. There's currently a pendant light in the middle, which I'll be removing. I then want to add 6 240v (UK) GU10 fittings. There's no insulation in the ceiling cavity as it's downstairs.
I don't really know how to go about physically wiring it all up though. The ceiling is Artexed (as much as I wish it wasn't!) and I really want to try and fit all this without causing a lot of damage to it, as I don't think I'll be able to match any repair cleanly.
I can get all the fittings in place without too much trouble, and I can slip a junction box into the cavity where the pendant is now. I can then fix that to be just flat and smooth, and cover it up with a smoke detector.
My problem is the beams:
I don't know how I'm supposed to get the wiring in between all the recessed fittings without cutting loads of extra access holes into the ceiling. I've got a decent threading kit, but:
- Do I just drill holes in the beams to thread the wires?
- If so, how? The holes required for the fittings themselves seem like they will be far too small to use.
