We're renovating a pier and beam house with a concrete ring wall that supports the outer walls. The existing walls are finished with vertically installed wood panels, approx 12" x 8', which lap over the ring wall slightly at the bottom. IOW - the outside of the ring wall is flush with the stud wall.
I'm going to be replacing the sheet siding, and I'd like to know what would be involved in installing a brick or stone facade.
