Let me first state that I am very green to anything electrical. I know enough to hopefully not kill myself, such as to turn off power at circuit breaker AND to still test wires and switches with a multimeter or similar.
I purchased a Hampton Bay Universal Remote Wall Switch to control my fan from the Wall.
Switch URL: Link to Switch I bought
The fan I am replacing in the living room is currently wired to be controlled by TWO switches.
The Hampton Wall Switch I am trying to install has three wires (black and black and green)
There appears to be 4 wires coming out of the wall for the fan/light (black, red, white, and it looks to be another white wire, but that could be paint? Ground?)
The way it is CURRENTLY wired is: Black Wire #1 comes from Wall and goes into BOTTOM of FAN Switch. Black Wire #2 piggy tails from main group of Black Wires into TOP of FAN Switch. Black Wire #3 piggy tails from main group of Black Wires into BOTTOM of LIGHT Switch. Red Wire #1 comes from Wall and goes into TOP of LIGHT Switch.
Here is a picture of the wall switch diagram: Wall Switch Wiring Diagram
Current wiring:
If you want to use the control with the new fixture, you'll have to only use a the single "switch" to control it. This means you'll have to replace one of the switches with a blank insert, or not use the control module.
Decora blank insert
In the switch box, wire the new switch as follows:
  • Black wire #2 (the one that comes from the black group, and goes to the top of the fan switch), connects to one of the black wires of the new switch.
  • Black wire #1 (the one that comes from the wall, and goes to the bottom of the fan switch), connects to the other black wire from the new switch.
  • Black wire #3 is either removed, or capped off using a twist-on wire connector of appropriate size.
  • Red wire #1 is capped off using a twist-on wire connector of appropriate size.
  • Connect the green ground wire from the new switch in with all the other bare grounding wires.
The wiring at the new fan will be as follows:
  • Connect the white wire from the ceiling, to the white wire of the fan control module.
  • Connect the black wire from the ceiling, to the black wire of the fan control module.
  • Connect the green/bare grounding wire from the fan, to the grounding conductor from the ceiling.
  • Cap off the red wire using a twist-on wire connector of appropriate size.
  • Connect the black wire from the output of the control module, to the black wire from the fan.
  • Connect the blue wire from the output of the control module, to the blue wire from the fan.
  • Connect the white wire from the output of the control module, to the white wire from the fan.
11
    You sir are a lifesaver! I wouldnt have figured that out on my own, and I have asked same question on multiple DIY forums, and have heard crickets. I really appreciate the clear and concise and detailed response. I am excited to try this tonight, and will post my results. Thanks so much!
    – Jim P.
    Sep 25, 2015 at 23:07
  • So I tried this last night and the wall switch would not work... I wired it exactly as detailed in your post. The only deviation was wiring the receiver module in the fan. The fan DID NOT have a blue wire. The fan ONLY had 1 black wire and 1 white wire. I capped off the blue wire from the receiver module, and the red wire coming from the ceiling. Any ideas? Thanks!
    – Jim P.
    Sep 28, 2015 at 18:15
  • The fixture does not have a light?
    – Tester101
    Sep 28, 2015 at 18:39
  • Do you have the dip switches (or however the unit handles channels) set on both the switch and receiver? The installation manual should explain how to set them.
    – Tester101
    Sep 28, 2015 at 18:42
  • The fan does have an integrated light fixture. The fan claims to be operated by the remote only. Not sure what that means, but I am suspecting perhaps that is why it only has two wires? Here is link to fan: homedepot.com/p/…
    – Jim P.
    Sep 28, 2015 at 19:17
