A contractor apparently did not a good job on rebuilding my deck and after a couple of months caulking in between wooden moving deck railings doesn't provide any sealing from water dripping into the half-wall underneath.
What's a good way to seal those corners? Assuming those wooden railings continue shrinking and expanding.
Miter joints are almost always susceptible to expansion issues like this. It's worse when exposed to direct moisture and heat. Caulking isn't going to entirely stop that from happening--may make it worse if it clogs the joint and leads to worse separation.
Some ideas:
  • Fabricate a metal wrap and drip ledge for the corner, if not the whole rail.
  • Rebuild with a different wood that's more stable.
  • Rebuild out of a composite material that'll never move.
  • Rebuild with a different joint maybe a simple butt or lap. In either case, consider sealing the end grain with epoxy or spar varnish to inhibit moisture wicking up the grain.
  • Thank you. Well, rebuilding is not an option. Building this one took them forever and I don't want to deal with that anymore. I'll take a look into the metal wrap idea. I was also thinking about a T-shaped piece of plastic or other material to insert there that would prevent leaking into it.
    – Nikita R.
    Sep 25, 2015 at 21:10
  • I'd pull up that 1x1" square molding and tack down a metal sheath under it then put the molding back -- kinda like flashing. I'd imagine a gutter or siding specialist could knock it out for you. The corner will be the trickiest bit to bend/cut correctly and someone who knows what they're doing will save a lot of time and possible lacerations.
    – evantish
    Sep 25, 2015 at 22:01
