The roll-out screen has holes at the ends of the metal casing, but these don't match the distance between the studs. The screen is ~80" wide.
Also, I am looking for a portable solution where I can easily detach the rolled-up screen when not in use.
I am thinking of mounting screws with hooks (or eyes) in the studs, and
option one:
- possibly using equal-length metal wire to connect the screw holes on the screen to the eyes on the screws (via carabiners or something like that)
option two:
- buy a 2x2 and cut to the width of the screen,
- mount the screen to the bottom of the 2x2 and
- add screws with hooks to its top, matching in position the screws in the ceiling studs.
Other ideas? Possible issues with what I have planned?
