I have a Whirlpool GR448LXPQ Electric Oven/Stove.
When the timer is set, it counts down to 0, then shows end, but it doesn't beep. The beeper, however, does work when pressing the buttons. I was wondering whether there is something I can do to fix it?
Thanks!
The beeper may simply have been turned off. Try pressing and holding COOK TIME for 5 seconds to turn tones on, and Snd ON will appear on the display. (This is from the Owner Manual.)
What I did was turn off the oven at the main fuse box, left it for a few minutes then switched it back on. The oven had reset itself and the beeper now works.
I just pressed and held the clock setting button and followed instructions to set the beep. I had inadvertently turned it off previously when I changed the time from daylight savings time.
my GE had the same problem not sure if it'll help. But I pushed the bake button then pushed the timer button without pressing the start button. by doing this the beeping sound came back. I did that by mistake just doing stuff and that worked for my oven timer to get it's sound back.
    I'm glad you got it figured out! Since that sounds like it might be specific to your model of oven, you could consider posting a new question and checking the "share your knowledge, Q&A style" box so you can answer your own question. – Cullub Mar 14 '17 at 18:34
