I am looking to install french doors to help brighten the room just outside of a basement bedroom I am currently planning (egress window added and all per building codes). All the other existing bedrooms in my house have doors which swing into the room. However, having the french doors swing out of the bedroom into a larger main room (not a hallway) makes the most sense to me for this bedroom since swinging into the bedroom would make me have to place the light switch further away from the door to keep the doors from obstructing access to the switch.
Also, when I think about it, it seems like every bedroom of every house I can remember has in-swing doors. But then, almost all of the bedrooms I remember also come off of a hallway of some sort where an door that swings into the hall would be an obstruction.
I primarily want to know if I would be breaking convention or some aspect of code/saftey which I have otherwise missed to install a door which swings out of a bedroom. One benefit I can think of for having in-swing doors is that an obstruction in front of the door wouldn't prevent someone inside the bedroom from opening the door.
