I am going to make some storm windows. 13 of them. The windows will be simple 1x3 frames with a 1x3 horizontal stretcher midway up. Mitered corners. I am including the measurements at the bottom of the question.
The question is - is there software or a trick that I can use to determine if I should get 8' or 10' or a combination of the two? Of course the system should also help determine which pieces to cut out of which board to maximize the wood use, aka minimize waste?
62.5" x 31.5"
62.5" x 31.5"
62.5" x 31.5"
62.5" x 33.5"
62.5" x 26"
62.5" x 26"
62.5" x 28"
62.5" x 24"
62.5" x 24"
62.5" x 24"
63" x 26.5"
63" x 26.5"
63" x 27.25"
