Is the Black & Decker "Codes for Homeowners" worth buying as a home improvement reference work?
closed as off-topic by BMitch Sep 7 '15 at 13:21
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions seeking product or service recommendations are off-topic because they tend to become obsolete quickly. Instead, describe your situation and the specific problem you're trying to solve." – BMitch
If this question can be reworded to fit the rules in the help center, please edit the question.
Yes, but in at least one instance, the text and the graphic are completely wrong, so be cautious. On pp. 40-41, the book indicates that you must have a smoke alarm "within 3 horizontal feet of the door of a bathroom containing a tub or shower." The actual code (in California, at least) requires that no smoke detector be any closer than 3 feet--to prevent false alarms from steam. (CA Residential Code chapter 3, section R314). A pretty serious misinterpretation.
It is a useful resource but in a very general way. It is not written for any one state or region so what you read in the book may not be exactly what your local ordinance see's as up to code. Also, each particular construction field is only briefly discussed. Maybe 2-3 pages that have maybe 5 topics on, for example decks. For a home owner wanting to get a basic sense of what a passing code is (but not necessarily in your municipality) this is a good primer.
